i have a englander 25-pdv 2008 model. im looking to replace my current combustion blower with a faster stronger unit that flows alot more air. does anyone know of a unit that would fit and do this?
Changing to a higher RPM motor is unadvised. Your controls are all set, to control, the RPM of that existing motor. You will essentially draw more combustion air in and exhaust more heat outside, faster...Not much advantage to that.
If you think the combustion blower is getting "weak" it is probably time for a thorough cleaning of the stove and vent. Oh and oil on the bearings wouldn't hurt. Check door seals and all gaskets for leaks.
Blowers either work or they don't. If you think the blower isn't moving air, something is in the way or the air is coming from somewhere else.
A bigger blower will only blow all the heat out the vent.
I pulled my combustion blower the other day after 6 years of operation. To my surprise, it wasn't too bad. Had a bit of black soot on the impeller that was easily removed with a brass wire wheel on a dremmel tool. I tried to remove the impeller, but she wouldn't budge with the set screw removed.
She burns a little better now, but not by much. I do the LBT once a month.
