OK, let me first say that I adore my little PDVC. I will never live in another home that does not have a pellet stove of some type in it.
However, my PDVC is pissing me off! I bought a house that had this stove in it and it was the light of my life for three years. I am in my fifth year here. Last year it was a little "moody". This year it is being a complete groan!
Here are the symptoms: It WILL NOT stay lit. it runs for four or five hours and goes out. Loading up the burn pot with pellets. ( I know I'm being cheap but those things are expensive!)
It is burning REALLY dirty. when I first starting using it it had this really nice white ash that I could clean out once a month. Now, I might as well be burning coal. Big clumps of slag.
It used to burn small...I mean, the actual "fire" would burn in the pot and the flames were these quaking, 4 inch flames. I was amazed to see how much heat came from those little flames. Now, I have a freaking blaze in there. I'm doing well to keep a fire going and the flames are HUGE. When it does burn, it burn CRAZY hot. the things actually makes this rumble sound that makes me feel like it's going to explode!
I have contacted Englander. They told me to set the three buttons at the bottom (I did this...although I can't remember the settings they told me...I'm on another computer.). It does a LITTLE bit better. still have black ash and the glass has now turned black.
I ordered all new gaskets. from the window to the burn pot. Haven't got them yet. (please tell me this is the problem and it will be fixed when I get them!)
I am using a good quality pellets. I use Lignetics. I tried that pennington stuff and developed nasal problems due to the dust and they burned Crazy hot!
I also ordered a new impingement plate. The back of the burn area is warped because of the heat. My impingement plate is burnt away about 3/4 of an inch up into the plate and about 2 inches wide. I can see the flames sucking up behind it.
I have cleaned this thing and done everything I can think of. I started it this year and it just started to go lame.
This one little stove is the main source of heat for my family. I have to stay up to make sure that it stays lit. I have to baby the thing to keep it going. Please help. Englander has sent me a reply but it doesn't seem to do the trick. Please tell me that the gaskets will cure this!
Thank you,
Odie Parkins
Cottageville, WV
Thank you,
Odie Parkins
Cottageville, WV
And we are not freezing either. I would be concerned too...dont blame you. How big is your house?
