Englander 25-pdvc e1 code
dustin baughman
1
maine
Hello I have a englander 25-pdvc and I have been having issues with an e1 code. I checked the hose and it is free of cracking and dry rot. And also swapped out the pressure switch. But neither has helped. Using the bypass keeps the stove running but i know this isnt a long term solution. What are some other causes of an e1 code?
johneh
4,933
Eastern Ontario
E1 Vacuum problem
Air leak at door or ashpan
Vacuum switch bad, Hose bad, or where he hose connects to the stove is plugged
Combustion fan not working or is dirty
The most common problem is Stoves plugged with ash
When was a complete intake to exhaust termination cleaning done?
Reactions: ericofmaine and ARC
