I've had it burning since about 4:00 today. Its in the basement and I had the windows and door open while the paint cured. I closed everything up about an hour ago while it was humming along at 525 deg. The smell isn't too bad but I'm about ready throw a few more splits on and get it roaring again. Its holding the temps steady upstairs maybe even rising slightly but its only mid fifties outside, on its way to the low 30's. With temps expected to hover around mid 40's tomorrow it should be a decent test for the Englander as the wife, who stays home, will tend to it. It should be interesting to see if it can keep the house warm overnight. Usually the Energy King insert on the 1st floor will let the temps drop about 5-7 degrees overnight when it is in the lower 30's. We usually wake up to 70 degrees downstairs. With the Englander now trying to heat the basement plus the top 2 floors I hope I can get the same performance. I can tell you right now it is much less drafty in the house. The convection currents tha normally setup from the insert are decently breezy, the Englander has to fight the 180 deg bend in the stairwell to get the heat upstairs and the cool air to return.
Some things I have noticed:
- The light show from the secondary burn ROCKS!
- The soot buildup on the window from the previous owners one and only burn has burned off pretty well.
- The draft from 40 foot of pipe attached is great
- A blower should help quite a bit. I found out today Home Depot near me doesn't sell wod stoves or accesories. WTH?????
- Im very happy so far, with the exception of having climb on the roof about 12 times more than I expected to install the liner and readjust 5 times and then do it all over becaust the liner fell out of the chimney.
- Did you know that you can install the cap with the stove puffing along at 450 deg? (it was the last thing I had to do today)
- Poor placement on the air intake adjustment knob. Its a thumb burn waiting to happen.
