Has anyone with the Englander series stove noticed a difference in smoke output depending whether the stoves air is set high or low.
After about a week of burning with the new Englander 30 i noticed it smokes on high air settings ,but not on low air. That is to say once i get the stove up to temp 500-600 stove top and reburn in full swing if i open the air from about 1/2 to full open even with vigorous reburn action from the reburn tubes i get considerable smoke from the chimney top,cut the air down to low or below 1/3 and NO smoke. I can however open the air fully once the reburn action slows down due to the the fire advancing past the initial off gassing stage. Can it be Too much draft pulling some of the smoke out before the reburn has a chance to burn it?
