Englander 49
What did Englander customer support, phone number on the first page of the manual, say when you called them?
Ah OK. Yeah the start of the heating season usually floods them with calls. Wish they could fix that.
Guessing that it is the 49-SHCMP multi-fuel stove. Several people here have them and should be able to help.
Welcome to h.c.
So if you press and hold the "Air On" button, the stirrer does nothing?
I tried that,it didn't do anything
Very odd. I did read a post earlier of someone whose control board wasn't hooked up correctly from the factory, Can you use the manual to check the connections on the control board (before assuming it's defective)?
Edit: also note that the wires can be pulled off when reaching in to the stove to connect a thermostat, for instance.
