Englander combustion motor options
joelswork
86
central TN
Hey all,
Just wondering if there are any places where I can get just the motor for the combustion motor assembly? The part number on it is J238-150-15138, I did a google search and just one company came up at $250. Mine isn't out (yet) but slowing down and squeeling more and more! What about rebuilding one, I have an extra but I'm thinking it was doing the same problem or the previous owner wouldn't have replaced it.
Huge chinkers/clinkers/ashpods....whatever ya call em
fully cleaned, ancient unit. Just doesn't seem to be getting enough air in the combustion pot
Hi joelswork,
The motor is made by Jakel. I have not found any OEM leads on them yet. I could try crossing to Fasco but that would be a down grade. You could also use this motor from this blower. If your in a pinch, Just make sure its turning in the same direction as the old one before you purchase it.
The old unit is a C-frame motor unit and the bearings are replaceable. Probably the cheapest bet!
You can also replace bearings, they are cheaper than motors which are cheaper than the blowers, etc ....
I am picking up some new bearings thursday from a local industrial supply. They had to order them for me but they are going to cost me 2 dollars apeice. I hope that it will solve my loudness issues
joelswork said:
The thing that concerns me is the difference in the cfm rating. The one that comes up as a replacement for my part number says 135cfm, http://americanhvacparts.com/Mercha...oduct_Code=MOT70219132&Category_Code=m-115vbm, the one listed above only has an 85cfm rating. could it just be from the impeller? Both say 3000 rpm
Where could I find the bearings?
Seeing you would just use the motor and reuse the old plate and fan blade. It doesn't mater. But make sure you get the right rotation.
I would opt for the bearings cheapest way out. Most industrial supply house's can get them for you. "Grainger" comes to mind, But there are several others t choose from. If there isn't any local, You always got the internet. Post the part numbers, we can link you some places that carry them. Or use google.
This is the one I used and it's the same as the one that cam out of it for $24. plus shipping and it came with a gasket too.
John
(broken link removed to http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380227273547)
