New poster here after reading post after post for several days.
After several weeks of dealing with E-2 errors on my 25PDVC stove, and dozens of comments here, I finally got it working right, I think! I replaced the window gasket (twice), the door gasket, and the combustion blower. I also cleaned the stove and flue. It has started twice now just fine.
Today I noticed something that looks awfully strange. The door appears to be almost 1/2 inch higher than it should be, I believe. You can see it in the pic. I added a dash line to make the misalignment more apparent. What this means is the lip on the door opening is nowhere near the middle of the door gasket at the top and bottom of the door. It is on the sides. I'm thinking the misalignment may be allowing leakage even though the fire appears to be healthy.
I'm considering cutting the stove side of the hinges down about 1/4" to lower the door so that the lip of the stove door opening will set closer to the middle of the gasket rather than near the edge. What do you guys think of this idea?
