Englander pvd25 stopped feeding pellets!
Ribcage
70
Massachuse
Woke up this morning to the pellet stove not working. Turned it back on and now there are no pellets being feed. I can hear the fan and the auger motor however the motor sounds as though it's zipping.. Any ideas?!?
Need a little more info. What type of stove is it. Is the hopper empty or bridged? If the stove ran out out of pellets it takes a couple of reset pushes to get them to feed all the way again. How old is the stove and when was the last time the combustion blower was pulled and cleaned? Does it have lubrication ports? Are you sure the funny sound is coming from the auger area? If so, empty the hopper and make sure the auger is not jammed with pellet fines, children's toys, nails or any other matter that might have worked its way into the hopper. Good luck and report back. :)
Zipping sound = stripped gears in auger gearbox?
Removed both augers and it seemed to be a jam. Scraped down the pipe as well as the pole and it's working well. I will hear a knocking noise now and then hope it's nothing major!
The knocking noise may be a pellet getting cut in two, as it gets caught in the auger.
Glad you're up and running!
Reactions: Ribcage
