My pellet stove runs for about 10 minutes then shuts down starts with an E-2 code then goes to an E-1 code. I've cleaned everything replaced the vacuum hoses and checked the heat sensor. anyone have a guess as to what is wrong?
when was the last time you took out the combustion motor and cleaned the motor,fan blades and chamber it is in? last time chimney was cleaned or checked for obstructions? E-2 is loss of vac. E-1 is failed to start.
I took it all apart and cleaned it out, I'm still getting the error Codes. I'm thinking it could be a vacuum switch? I've replaced the hoses. It will start and get up to temp then run for about 10 minutes then shut down
Take a picture of the wires on the switch with your phone then pull the 2 wire and connect them with a paperclip ( don’t let the wires touch anything) plug the stove back in and start it up.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
