Hi there,
My first post. I installed a used EF3 last year, and have been burning full time (except june til sept). Cleaning every 2 days. Deep clean a few times in the past year...
I’ve not had an auger jam so far. However, last night I heard a “pop” sound, and the auger immediately stopped. The auger light continued, but there was no auger movement. I unplugged the power to the auger, and plugged it back in, and auger continued again for 4-5 minutes (with a few grinding sounds) then quit.
After a bunch of reading on this forum, this morning, I emptied the hopper, removed the auger and motor, vaccumed the whole thing, the brass bushing “looked” ok (but not 100% on these things, and I couldn’t seperate the motor from the shaft). Seemed any jammed was cleared, and put the motor/auger back in place. Auger spun freely for a few minutes. So I loaded up a scoop of pellets, fire ignited and ran for 10-15 minutes. Had a few grinding sounds, then “pop/snap” sounds again ... auger quit.
Sounds like i’m pulling that auger out again, but for a bushing? Gears? Motor itself?
I’ve checkd the temp sensor red switch, it appears to be pushed in. And I checked to make sure the motor is getting power. 110volts.
Any help or insight is appreciated. Because of the holidays, most shops locally are closed, and I have a bit of a chance to see if there’s something I can do to get some heat in the meantime.
-jay
-jay
