countk said:
Thanks all for the advice.
I jumped the two wires together to bypass the vacuum switch, and the stove is humming along beautifully. So a few questions.
1st off, in layman's terms, why is this switch needed? I know it's about negative pressure and airflow and all that, but what does it mean? So can bad airflow cause carbon monoxide or any problems to the stove?
If things are running great with the vacuum switch bypassed, which they are, does that in all likelihood mean I need a new switch, or could it be something else??
As stated earlier my technical ability is very limited, so I wont mess around with a motor or probably anything else, however if it is likely the switch I can install that at least and avoid a service call.
Any and all suggestions welcome! Thanks!!
One: Jumping out the vacuum switch actually says nothing about weather the switch is bad or good.
Two: The vacuum switch is one of two extremely important safeties on the stove, it is there to make certain that the combustion blower is operating and that there is a path up the flue for the exhaust gases to exit the stove. Exhaust gases containing CO are present in all fires.
In layman's terms it is trying to prevent you from dying.
Three: Never run the stove with the vacuum switch (or any other switch jumped) except to verify that it was in fact a vacuum issue that stopped the stove from running.
Four: You still have to find out what is really the problem.
It can be a dirty vent, ash plugged stove (this includes the tube that goes from the vacuum switch back to where it attaches to the stoves exhaust or heat exchanger).
I will repeat while it is possible that the vacuum switch could be bad, it is highly unlikely that it is, and jumping it out does not prove it is bad.
Most vacuum errors turn out to be ash in the works (dirty stove issues).
