Some time ago I added an OAK which is a straight piece of 4" metal piping out through my chimney with a screened end piece. The stoves standard inlet piece (before I added my section of piping) has a metal flapper on it. When the stove is off, the flapper is closed. When the stove is on the flapper opens inward, the higher the fan speed the wider the flap opens. I know this because I can stand out side my chimney and look directly into the OAK ( with the screen cover removed) and see the flap either open or closed.....
So now I have a power failure, smoke question. Like most insert owners, I probably have abundant natural draft with my exhaust going up and out the chimney (forget my UPS for the moment).....but then I think about that FLAPPER.......and I wonder about other makes of stoves. Do they have flappers on their combustion inlet? I ask because of my perceived safety understanding of an OAK. Isn't an OAK an extra way to vent smoke out of a stove....besides the stoves exhaust venting? If yes, then my flapper should be removed because it only opens inward........yes? no?
If my power goes out, the natural draft of my chimney should draw out all the smoke.
If I remove the flapper does my OAK now also act as an escape route for the smoke? Or....
could the added venting actually help increase the natural draft in my chimney? Why even have the flapper?
Thanks, Bill
Thanks, Bill
