After reading threw the Owner’s Manual and some of the forum I’m still a little confused on the HI/LOW mode. The Owner’s Manual tells you about the different jumper settings which make sense, then about mounting the thermostat on a wall not closed to the unit, what thermostat? Was the unit supposed to come with one? I have searched around but not sure which thermostat to get for my unit. Any help is appreciated,
Thanks.
Thanks.
so thank you for your time! I had one more question off topic. With your mini do you have horizontal venting, or do you go up the recommended 3-5 feet vertical?
