Error code 0 rika austroflamm integra insert what could be the cause
bke7
32
Northwest CT
our rika austroflamm integra insert was running great , then just shut down with an error code 0
Have no idea what this could be caused by.
Manual is absolutely no help regarding error codes.
Stove is clean , flue is clean both the low limit and high limit switches are functioning correctly .
I can restart and it starts fine , runs for 10 min or so then just shuts down with the same error code 0
Pellets are feeding as they should so no blockage , ignites as it should .
Any thoughts will be greatly appreciated
It sounds like whatever tells the control that the stove is up to temp is not working, be it a thermocouple or snap disc. Perhaps a bad connection, either at the control board, or along the way to it.
Replaced the low limit switch.
had a low limit switch on hand it is a 140 degree the factory is 120 , don't think that is a huge problem
Did a complete and thorough cleaning of the stove and flue.
Replaced the gaskets on the low limit switch and the exhaust fan
Cleaned the air sensor
Restarting now , fingers crossed
That difference might take too long to get up to temperature and cause the stove to shut down especially on low heat levels.
Stove is up and running again .
I ordered the correct temp low temp sensor and will swap it out.
Pretty cold last night stove is running great
Thanks everyone
