Brenn have you tried burning a full load of nice seasoned softwood?
 I think you may be on to something here
@Builderml .
No I haven't tried all softwood. A piece or two here and there, but that is it...very interesting indeed. I have been burning some Ash and Cherry, a lil Elm too. All the rest of my stuff is
even more BTU packed so...
I do remember reading of these guys (Tundra owners) have problems with coal buildup during the really cold parts of the winter last year. It is a EPA firebox issue, the stove guys have it too when they push 'em hard.
One feature of my temperature controller is the ability to have it open the damper when the flue temp drops too far,
@3fordasho  has been using his to reduce coal buildup. I haven't used that feature yet because I thought it would reduce "burn time". I haven't had a coal buildup problem yet, but, it has been warmer out and I haven't been loading fresh wood onto a big pile of coals...heat output is defiantly much better with flames rolling in the firebox. I can really only raise the temp in the house when I have flames...looks like I have more things to try now.
1. Use the low temp feature in the temp controller.
2. I had thought of removing the insulation blanket behind the firebrick in an attempt to get some of the heat from the coals to pass through the firebox walls to the air.
3. Insulate the cabinet. There is a ton of heat lost to the furnace room as I said before.
4. Install supply plenum.
5. Maybe try to fab up a grate like
@KARB2014  did? The more I think about this...yeah, the ideas are rollin now!
If I recall correctly, this was the exact problem spidey had with his "stovace" in that thread(s) that I had mentioned earlier, this was over on AS a couple years back....coal buildup and no heat output!
Maybe this is why my Yukon was working so well for me as far as heat ouput (other than being cantankerous to get "dialed in" on each and every load) because I have both air under the fire and now a proper secondary burn system. (I modded the secondary air system)(the factory secondary burn system is better than nothing, but just barely)
