FA264CCL
tnelson0625
1
NJ
I recently purchased another FA264CCL that is in better shape than the one that i currently own. There are some differences in the new one that I am unsure about. Hope someone can help.
1. The combustor chamber contains a round steel disk with a series of holes. I believe that this may only be needed for coal burning. if i plan to burn wood, and plan to buy a new combustor, then i'm thinking that i do not need to use the steel disc....correct?
2. the stove has fairly new grates. the side shaker grates seem to work well. i'm not sure if the new fixted center grate is installed properly. does anyone have a photo that would show how it is supposed to look? it protrudes way above the side grates.
3. the square plate underneath my combustor is soild. where my other stove had a square plate with a series of holes. does anyone know why that plate was solid? i plan to use the combustor, so i will need to purchase the plate with the holes in it. or can i just drill my own holes?
4. any tips on how to cut gasket material without fraying the ends?
These stoves are now getting way up in age - maybe 20+ years, so the information about them is starting to go away....
My guess is that the round plate is simply a flame spreader for the combustor - the square solid one stops the flame and piled logs from hitting the combustor.
The grates sound right - I seem to remember it like that. The higher center one helped feed coal to the shakers. With wood it really should not matter.
Gasket will always fray - I just add a bit of extra cement near the ends where two pieces meet. High temp - orange or black - RTV silicone will probably do a decent job in most cases also.
