Fahrenheit 50. Fahrenheit Technologies Out of Business
Jay Z
27
Palmyra, WI
My auger motor went on Monday. Made a call to Michigan at Fahrenheit Technologies and found out they closed that part of the business. The have switched to pellet grills a few years ago. I did have a email back in November from they engineer on some venting but nothing was mentioned.
Do you know of any dealers that might have Fahrenheit 50 parts. I did find an exact replacement motor so hopefully it works.
I'm not familiar with that brand at all, but if it's the Fahrenheit 50F then a quick search showed auger part number
CS1-9444 ​
Another quick search found this:
https://www.eastcoasthearth.com/collections/parts-for-fahrenheit-furnace. Not many parts on that link, but often electrical parts can be matched with something not directly from the manufactured with the exception of proprietary parts like control boards.
Usually for things like auger motors, I find the spec and try to buy them directly from the manufacturer of the part like Gleason Avery in the case of many brands auger motors .
CS1-9444 ​
Thanks for information. I got 10 years out of the motor and got a replacement from East Coast. My furnace is USA made in Michigan so I should be able to get most things. Now I am on the hunt for burn pot parts.
Did you ever find somewhere that sells parts ? I need the brash bushing on the auger
There is a way to easily use a different bushing, shown in this thread-
And, Don may know of a teflon one that may work.
I just found out today that Fahrenheit closed up shop back in November as a result new bs unreasonable EPA regs.
There were a couple of dealers that purchased the bulk of Fahrenheit's inventory before they went out of business:
https://cherryvalleystove.com/
(broken link removed)
I had to order a few minor burn pot parts so I contacted Fahrenheit a couple of weeks ago - I normally only contacted them every few years or so for parts and service-related questions. I've also had my Fahrenheit 50 for just over 10 years...I swapped out my auger motor several years ago and more recently replaced the entire electronic control module. Only other parts I've had to replace were burn pot parts.
I had to order a few minor burn pot parts so I contacted Fahrenheit a couple of weeks ago - I normally only contacted them every few years or so for parts and service-related questions. I've also had my Fahrenheit 50 for just over 10 years...I swapped out my auger motor several years ago and more recently replaced the entire electronic control module. Only othparts.er parburn pot parts. I've had to replace were burn pot
Besides some relight plates and gaskets, we are out of burn pot parts. We do still have some augers and blowers etc.
Cherry Valley Stove & Saw
9790 Cherry Valley Ave SE
Caledonia, Mi 49316
616-891-7500
Finding Fahrenheit 50 parts might be tricky now that they've shifted focus, but you're on the right track with sourcing an exact replacement motor. For other parts, you could try reaching out to local HVAC or pellet stove repair shops—they sometimes stock discontinued parts or know where to source them.
I had to order a few minor burn pot parts so I contacted Fahrenheit a couple of weeks ago - I normally only contacted them every few years or so for parts and service-related questions. I've also had my Fahrenheit 50 for just over 10 years...I swapped out my auger motor several years ago and more recently replaced the entire electronic control module. Only other parts I've had to replace were burn pot parts. Technology is evolving quite rapidly nowadays, and if you would like to keep up, I recommend this blog about LXP case study, which can really help you develop your technological awareness.
If you’re looking to keep it running, it’s great that you were able to find dealers who stocked up on parts. Cherry Valley Stove seems like a solid option for future needs. You might also want to check with online forums or community groups dedicated to pellet stoves; sometimes users share resources or even 3D-print hard-to-find parts.
