Hi
I live in earthquake country and as a result, removed our masonry chimney. The chimney had cracks when we moved in so we had installed a Lopi Patriot and a stainless steel liner through the chimney. We will now have an alcove where the fireplace was and will reuse the Patriot with double wall metalbestos chimney running through the attic and out the roof. I have two questions--first, I like the look of Rumford fireplaces as well as their mechanical advantage of having more heat move forward.
Does angling the walls of the alcove give any similar advantage? (My idea is to first put up two layers of wonder board around the alcove to more or less fireproof it and then frame inside of that with steel framing which will have more wonder board and tiles.) There is not enough clearance behind the stove so we will probably do the 1" air gap up that wall.
The second question deals with blowing the hot air from the stove into the room. Our house was built in 1910 and has little insulation and single pane windows but we are in a moderate climate SF Bay Area). It would be nice to get more air flow for the heat produced. We had an ecofan but that did not seem to get much air movement. I am thinking of putting an electric fan towards the top of the wall above the wood stove. It would blow from the alcove into the dining room. is this done and does it make sense? Do I need special fan and metal shroud if it is up 8'? Any recommendations?
I am thinking I will probably go up one 4' section of single wall pipe before switching to double wall. Does that make sense? All of this is being done with a building permit.
Thanks
Rob
Thanks
Rob
![[Hearth.com] fan in a stove alcove wall? [Hearth.com] fan in a stove alcove wall?](https://www.hearth.com/talk/data/attachments/201/201409-615ab29c24b9921e0d3d1ef0e46d53c9.jpg?hash=wYrZ18656u)
![[Hearth.com] fan in a stove alcove wall? [Hearth.com] fan in a stove alcove wall?](https://www.hearth.com/talk/data/attachments/201/201410-9245822e4303aec10c03dcd15d4ad53d.jpg?hash=oVRO0DcWAO)
![[Hearth.com] fan in a stove alcove wall? [Hearth.com] fan in a stove alcove wall?](https://www.hearth.com/talk/data/attachments/201/201411-66852917b261af1279e67c2a7bbfa95a.jpg?hash=xMKyn2cWeA)
