I've read several posts on the M55 overheating issues since my stove started to trip the high limit switch. I have the original non turbo blower in my stove. I have burned about 30 bags without any issue until yesterday when the limit switch tripped. Stove was set at 3, combustion at 1 and feed trim at 3. I cleaned the stove and reduced the stove to two but it still tripped. The feed restriction plate was installed last year and I fixed the earlier problem with the stove overheating.
I never really played with the feed trim or combustion before. I am going to reduce the feed trim to one and see if this helps. Does the feed trim reduce the quantity of pellets or increase the time between drops? How would I know it is time to replace the blower for the larger output model? Thanks in advance.
Kevin
Kevin
