Hello folks,
We moved into our home a few years ago and are unsure about what to do with our basement fireplace. Although we'd like to use it, we never have. I had it inspected by two different companies—one was a chimney sweep company, and the other specialized in rebuilding fireplaces. Despite the appearance of the firebox, both companies confirmed that it is in perfectly fine condition, although not entirely up to code, and would be safe to use. Unfortunately, we can't afford the proposal's hefty price tag to make it visually appealing.
Part of the issue is the slope from the laminate floor tile to the firebox bottom/floor. I haven't measured it, but it likely slopes down between 1 to 2 inches. So, for me to build a new hearth, I either need to add mortar/concrete to level that area with the floor or chisel it out and level it with the firebox. Another problem is those terrible white floor tiles very likely contain asbestos. I prefer encapsulation over removal.
Could I put a form around the fireplace brick, level this with refractory mortar or cement, and then tile around it? It would have an edge around the fireplace brick (like this |__).
I appreciate any thoughts the community has on a DIY solution for a hearth.
Thanks,
Mac
Thanks,
Mac
