So I know the answer if this is about wood heat. Stove. However I don't know if this rings true for gas units.
Here's the question/situation:
We heat with wood. Primary heat source, no furnace. We'd like something as a backup that can heat the place should we need to be/want to be away during the winter for several days. I don't trust plug in electric heaters. I also don't trust the VF that much, although it might be able to do it. We were looking into splits/hyper heat units but now I'm thinking maybe just a stove or fireplace in the porch we are wanting to rebuild. This would then be a part of the house and could be opened to the house to circulate heat. We'd have to find a way to feed it (LP tanks somewhere, we use 2 100lb tanks to feed our range and water heater and a third one to feed the VF when it's on). Not entirely sure if this is how we'll go, or if we'll be able to rebuild the sunroom anyway, but I like to get some rough ideas together in case we do.
House with rebuilt sunroom would be in the range of 850 heated sq ft. One story. Sunroom at one end. We're getting better insulated and sealed, the Republic can heat the place easily unless it's in the single digits or teens with high winds.
We would want a little "bump out" for the fireplace or stove to keep as much floor space in the sunroom as possible. So the stove would basically be installed like a stove in fireplace install (alcove).
We've heated with a gas stove before, and now a wood stove but I don't have a comparison for using a fireplace. Which would likely heat better? Stove or fireplace? Do gas fireplaces use a blower the way wood inserts do, to circulate the heat?
