Fireplace Inserts are not something I’ve spent much time researching about it reading forum threads about simply because I have no use for one.
A few days ago a friend asked me to keep an eye out for a good, used, wood insert for him. Naturally, if I am tasked with this job then I need to do some research. That’s where you guys come in.
Obviously, I want to help him find a well built, well liked, highly recommended and more efficient wood insert.
This guy is a cancer survivor, is on disability, is also a Vietnam Veteran and so has a limited budget. As such I feel I am tasked with taking my time and finding a quality, well made insert for a song...cheap as I can.
I do not have his fire place measurements yet, or the size and height of the chimney. His home is likely a 80’s/90’s brick ranch of about 1600 sq ft.
I know a BK insert would be awesome for him, but not sure if I will find one, so I need to know what other inserts you guys might recommend. I imagine they might be the same as some of the higher quality stoves, but I’m not sure if there things that I need to look for as far as fit, or if the the fireplace needs to be altered for fitting of the insert, or if fireplace damper needs modified. I’m going to have a heck of a time convincing him to install a liner in his big clay lined chimney. I’m a clay liner guy if it is sized right, but in this application he’s going to need a liner for best efficiency.
All help is greatly appreciated.
Any insert recommendations?
