Some interesting (to me anyway) observations about my Fireview and the cookstones as they relate to the surface temperatures. I'm hoping that someone else out there may have them and may be able to report back their experiences with them too.
Background:
I bought the FV and at the same time bought a pair of the soapstone cook stones. For those who don't know these - they are perhaps 1" thick soapstone pieces that are cut to fit exactly on the top of the stove within the 'frame' of the cast iron surface. One goes on each side. I bought them since I planned to keep a pot of water on top all the time and also figured on cooking etc so figured it would protect the nice surface of the stove (can always replace the cook stones I figure).
I knew that these would take longer to heat up and thus the thermometer would lag on temperature changes (up and down). So to engage cat etc I would have to watch the flue temp as much as surface temp. Ok, no problem there.
Observation/experience:
Burning with the stones in place did indeed result in slower surface temp changes. I put the stones in place shortly after my burn in fires and kept them there 24/7 pretty much ever since. Now this is where it gets interesting. Once it turned colder and we went to 24/7 burning I noticed that although we were nice and warm I never got really high surface temps. In fact never over 450 generally, perhaps 500 once. I thought this was odd compared to what others reported as their temps... I wanted more heat from the stove if/when it gets really cold so wanted to know if I could get to 600 or at least 500.
The experiment:
I had a thought last weekend that maybe the stones not only slow down the heat transfer but may actually lower the max temp on top of the stove. Makes sense if you consider the air gap (small though it is) between the stones. So with the stove top steady and reading 425ish I removed the stone under the thermometer and set it down. (that was hard and interesting, hot stone to move!). The thermometer quickly registered a temperature over 550! It then settled down around 600. Hmm...
Rest of weekend I ran without the cookstones in place. Surface temps consistently ran higher than they had with the stone there.
Conclusion & Implication (?):
I am left to conclude that for my stove at least the cookstones are acting to significantly reduce the surface temp on top of the stone. Not too surprising really, but something I had neglected to consider before for some reason. I had expected that once the stove got up to temp the surface temp would get very close to what it would have been without the stone there - certainly not more than 150* difference.
Now I doubt this really makes much of a difference in terms of actual net stove heat output into the room but there may be arguments on both sides of that question. However, the critical implication of this is that if I'm using the cookstone, I can't use the surface temp on it as my guide for the stove's red line top safe operating temperature. I can only guess what temperature the stove would have to reach to get the top of the cookstone to 650* but it would certainly appear that it would be quite a bit higher.
Thoughts anyone?
Background:
The experiment:
Thoughts anyone?
