Hello All,
I have installed a Fireview into my hearth (built for a stove). I am using an outside air kit and the stove vents into a 7"x 7" exterior masonary chimney that is at least 25'. I live on the top of an exposed mountain where it is always windy. I had some issues with run-away fires with my last stove (Avalon Rainer) using the same set up. It is a strong drafting chimney.
I would like to keep the stovetop in the 400-500 deg range, but I am having trouble doing so with anything other than one split or kindling in the stove.
Last evening I put 3 splits (4-5") in the stove which filled it 30%. I had nice gentle flames and noticed the stovetop temps in the 550 range (air intake at 1-2). When I try to close the damper (less than 1), the flames dissappear and I get intermittent bursts of flame in the stove which cause the stove to puff smoke from the air intake.
Is it me? Do you think I should disconnect the oustide air intake? Use the flue damper?
I would love to fill the stove at night and not have to worry about temps going out of control. How do you get sustained low temp (400-500) burns?
Rick D
Rick D
broken link removed to http://www.woodheat.org/outdoorair/outdoorairmyth.htm)
