Problem (or probably an indication of a problem): A mostly blackened door glass after the first 24 hours of operation.
I filled the hopper with 2 - 40lb bags of Southern Indiana Hardwoods, Inc. Premium Wood Pellets (less than 1% ash) gotten from TSC here in Columbia, Tennessee. Pressed the "On" button and it fired up. I set the Heat Range on 3 as per the instructions, and enjoyed nice heat and seemingly proper operation for the first few hours. The flame was active and lively (not lazy), it pulsated as it should, and there was no blue flame at the base of it indicating overburn. Enjoyed the ambiance and went to bed later. When I got up the door glass was already dirty but could still see the flame and the sparks fly when the pellets dropped. I let it burn to 24 hours of operation and shut it down. I know this glass getting this blackened this soon is not normal and indicates some problem and a reason for it, ...so what should I do? What adjustments should I make on the draft air and/or other settings? Or whatever??
Consider that there are 3 elbows (one more than recommended), that I used a fitting to increase the exhaust air vent from 3 inch to 4 inch out of the stove, and after using the elbows to get it where it would have good clearances (about 14 inches off center) the vent goes straight up through the ceiling and expands into a 7" vent pipe which goes on through the roof to a proper height for good draft. A vent cap is in place.
Would surely appreciate any thoughts, suggestions and recommendations....
Yakatony
Yakatony
