Hello,
I have been lurking for awhile and used the info here to buy my Regency F2400 stove. I did a burn this morning and have a few questions as my last stove was a non EPA stove years ago.
After getting a bed of coals, I added some small to medium size pieces and waited until most were charred. Then I closed down the air all the way and waited for the flames to adjust then slowly opened the air until I saw a secondary burn (I think). At one time the wood just glowed and the flame was around the tubes, but it didn't last long. The flue temp (probe type) was almost 700 deg. I adjusted the air until I had a small amount of flame with some secondary burn. Is this the correct way to burn the EPA stoves?
Also, I noticed the wood at times would pop/crack although I did not notice any moisture or sizzling on the wood ends. Is this normal? Most of my wood is 20% or <. I would guess some may be higher as I have a mix of hard woods, maple, hedge,cherry, ash,locust and my ability to tell the difference by looks yet has not happened.
Thanks
Thanks
