59* outside now and going into the 40's. I don't really need a fire but it feels damp inside and I just want to sit and have a beer with my stove.
I've been running my P43 since it got installed this year in Feb. I have to do the cleaning, but the weather is nice here this fall. I have my 2 pallets (140 bags)in the driveway now. Got a new fuse panel with switches up and running (5 fuses/switches). Going to change the door gasket as it leaks. Love it.I did my full - just before the season service a couple weeks ago, but haven't fired it up yet. We had a couple mornings in the mid to upper 40's but it's warmer again now. I got 4 tons of pine pellets delivered last Monday and I'm kind of looking forward to the fire.
I usually to 2 annual cleanings/service. at the end of the season, I do a thorough ash clean, including scaping the inside walls and brushing the whole vent, Leef blower trick, cap the vent and outside air, and put a container of DampRid in the ash container.
Then right before the season is my second service. I inspect gaskets, get the chimney ready, lube the bearings on all 3 motors with Wurth HHS+ which migrates into the bearings, lube the bearings and pivot points on the feed mechanism, wipe everything down, and use some stove black polish if needed.
Wow I didn't expect it to be so cold there so soon! We went down to about 8 C the last couple of nights. I have the heat pumps on heat mode now and heated the house up (the main floor) with them this morning. The basement is cool but that is OK. Going to clean stove today. You were right about the amount of dust I'd find in my venting. Maybe a couple of cups of dry dust. NO CREOSOTE! YES!Sept 21, 8 am, there is a heavy frost this morning, the temp. is -1.4
Need heat this morning . Syove is on house is starting to warm.
Just checked first time in 15 years we have needed the stove this early in the fall
Maybe what they are saving long, cold, dry winter on the way
Just finished my fall full clean and test fire!Stay Warm!
Your post is a reminder I need to do a full cleaning on the stove and chimney.
Usually first fire is in October.
I just finished mine too (P43). I am going to post some pics that may help new owners. You have a really nice setup!Just finished my fall full clean and test fire!
