I recently got my Baby Bear installed, I also added the "simple baffle" that Coaly came up with, but have only lit it a couple times. I'm wondering if I need or could benefit from a flue damper? Looking at the manual, no diagrams show a flue damper and it actually says not to add any additional dampers to the flue outlet. After letting it get up to temperature with air control open and then completely closing it for approx. 10 minutes, I have used an infrared thermometer on stove top and double wall stove pipe. With the front (lower) top 500 - 540 degrees, the back (upper) top reads 395 - 400 degrees and the double wall stove pipe is reading 220 -250 degrees at it's hottest spot 4" above the T attached to the stove flue. So my question is, should my stove pipe be cooler and would a damper cause it to be cooler and allow longer burn times? Thanks for any and all assistance.
