High Flue Temps and Difficult Cold Start with Jotul F602 V2
AILDWarrior
60
Kenai Peninsula, AK
Greetings! I want to start by saying that I operated nuclear reactors on USN submarines, and this little stove is substantially more difficult to operate than a reactor. On a more serious note, I grew up around wood stoves, specifically a pre-EPA Scan, so I'm not unfamiliar with wood burning, though I'm certainly not an expert either.
I've frequented this site a lot and found a lot of valuable info from BG that has changed my burning habits, but I still have two primary questions I haven't been able to answer: (1) what are normal flue probe temps for these stoves when in the 400-600F stove top temp band? and (2) how on earth are you guys lighting these things to get a decent coal bed?
I'm burning Sitka spruce, with fresh splits ranging between 16-18% and my house is about 800 sqft. Double wall stove pipe (Excel), about 15 ft tall. At peak temps, the stove top is 450F between the flue adapter and the cook plate, while the Jotul logo on the front is about 580F. At that temp my flue probe typically reads between 800-900F, which seems absurdly high to me, though I'm wondering if I'm just inexperienced and this is actually normal. Flue probe is Condar, 18" above the stove top.
I typically light top down, starting with 2x 3-6" pieces, then 2 or 3 layers of 1" kindling and a fire starter at the top. I recently watched a Jotul video and tried two stacks of 2-3" fuel pieces on the bottom, separated by kindling for air flow, this second method is new to me but seems to be working slightly better. My main issue is that the kindling lights up great, and I progressively shut down the damper as flue temps approach 400F. By the time temps hit 600F, I'm all but shut down on the front damper, just a sliver open with a healthy blazing fire. 10 minutes later, the kindling is burned out and my bottom logs are smoldering. Then it's a 2 hour fight to cut the smoke and get enough flame to keep a sustaining fire. Very frustrating. To me, it seems like the major issue is no air flow under and between the bottom pieces of fuel when cold starting.
For additional info, I had a minor chimney fire with this stove last year due to a poorly positioned 45 elbow near the ceiling and wood that was very poorly seasoned and stored. Since then, I've learned a lot, especially from this site, and I have a proper shed for 6 cords of wood. Like I hinted at earlier, I'm mostly just frustrated because this stove seems so difficult to control compared to the Scan I grew up with. I've dialed in many of my issues, but the high flue temps are making me nervous and I'm convinced that my issues with cold starts are due exclusively to operator error. Once I've got a good coal bed, I feel like I have pretty good control over the stove.
Sorry for the long post, and thank you for taking the time to read it and provide any advice you might have!
Try starting off with just kindling to get a coal bed established then rake all the coals forward and add your splits. The 602 has a small firebox and all the combustion air comes from the front so it burns front to back. Top down fires are difficult with this stove in my opinion, just not enough room. Another technique is what I call the sandwich method. Lay two small splits side by side, small kindling on top front then another two small splits on top.
Sometimes these stoves burn too hot because the front air control doesn’t shut completely. This can be fixed by taking the air slide apart and grinding down the slide stop. There’s a video on YouTube somewhere on how to do this.
Reactions: AILDWarrior
At room temp?
Things I’ve learned to get fires established quickly. Use Lots of kindling. Like 1/3 to 1/2 a fire box. I like pine for this. Use whatever you have and it split small. I have a bigger stove and sometimes only get 2 real splits in on a cold start. You might even crack the door a bit to help it take off but ALWAYS set a timer anytime you crack the door.
At 15’ you’re not tall but if it’s -40 and windy you might be overdrafting. A pipe damper is can help control flue gas temps.
At room temp?
Yes, I checked the moisture at room temp and split within the previous 24 hours. After my chimney fire last year, I found it helps to ease my anxiety by batch testing the moisture content on any wood I bring in. Saves me $200/hr by avoiding a therapist 😉
Thank you Todd and EbS-P for the advice. I took it and mashed it with Jotul's video and tried something different that seemed to work this morning. Two E-W pieces of kindling to elevate 2 small N-S splits followed by 3 stacks of kindling and a lighter between the top two stacks. Appeared to burn clean as intended and the elevated bottom splits ignited MUCH better, getting the fire hot and leaving a nice set of coals for refuel. I'll keep working at this, but I feel like I'm finally working toward a solution.
As far as the flue temps, I found another thread on this site that made me feel a bit better:
It sounds like I might be near the top end of the band, but that's not entirely unexpected with an EPA catless stove since these machines force higher flue temps and don't use the cat to strip additional heat before entering the pipe. Todd, I've come across your threads before regarding the damper modification. I'm tempted but I also haven't found myself overfiring the stove yet, at least based on stove top temperature. I haven't convinced myself yet to file down the stop tabs, though that day might come soon enough when I start burning birch.
I haven't run the v2 version, but would aim for flue temps once the stove is damped down to be approximately around the stove top temperature with a probe thermometer.
I use a propane torch for a few minutes to light my Osburn stove. I used to do the kindling thing but now I just put in the logs (mostly spruce and poplar where I am) I want to burn, light the torch and aim it at the bottom of the log pile and close the door as much as possible to keep the smoke in the woodstove - and away it goes. Split logs are arranged north/south. My stove has a front shelf that I place the torch on and I watch that once the fire starts nicely, I remove it. My stove is, of course, different than yours and I was having a devil of a time getting it to light, then one suggestion was to remove or partially dislocate the cleanout which is on the bottom of the stove and that REALLY made it easier to get started as air would directly get at the bottom of the fire. Once going I replace the cleanout plug.
With some wood burners bigger pieces on a cold start need to be well charred before closing the air at all. My 30NC stove at the old house didn't need this too much, the Stratford 2 zc here in the new place absolutely does.
So I have two medium splits cruising in the second stage of the burn right now, with the stove damped down. Flue temps are 550-600F while stove top closest to the flue is about 350F. The 200F difference is pretty consistent when the stove is happily burning away. When I get the stove top temp up to 600F, the flue is almost always 800-1000F. Am I doing something wrong here, or is this just the way she goes?
I might have to go that direction if I keep struggling with top down. As of today, I'm having much better success elevating the two bottom splits with two small pieces of kindling acting like a grate. The torch might have to make an appearance though...
Try putting the bottom splits north/ south. Then up from there. I don't know where the intake air pulls into on that stove? One of the others might know. I keep ashes in my stove and I clean out the north south center and then build from there. My stove likes it. Worth a shot! Sometimes it takes some trial and error to get stoves dialed in but once you do...
I think my 602 CB internal flue temps were pretty close to the external stove temps but I did occasionally see spikes in the flue temps up to 800+ if I didn’t close the air soon enough.
My primary air slide closed completely giving me more control. Even when it is fully closed there is still combustion air coming down the air wash. With good dry hardwood I was able to still have some coals after 6-8 hours and the stove gave off good heat for 5 hours.
Yes, with good draft, turning down the air fairly aggressively and quickly helps. So does burning thicker splits. FWIW, if I wait too late on our stove the flue temps can also spike up around 800-1000º for a bit. Riding herd on the air control with a digital probe for guidance avoids this.
Thank you all for the insights! I get the feeling that I'm probably jumping the gun on shutting the air down too early during a cold start and am waiting too long to shut it down during a refuel. FWIW, I've never been able to get hot coals after 6 hours, maybe 2.5-3 hrs at best. However I'm only ever adding two large splits at a time and don't stuff the box. I've been too nervous to pack it full since only two splits make it feel out of control.
Also, for anyone who may come across this thread and find it useful, I was a dummy and left my stovetop fan going on the cook plate when using IR thermometer for temps. Taking the fan off brought the stovetop temp up about 75-100F between the flue adapter and the cook plate (remarkably , these things actually do transfer heat and are not just a gimmick haha). This brought my stove top temperature to within 100F of my flue temps, much closer to what begreen was recommending.
I may end up filing down the tabs on the damper as Todd recommended. If that happens, I'll be sure to come back to this thread and update results. Thanks again!
Also having some issues getting fires started in this stove as if it's air-starved. I have air open all the way and keep it there. Chimney has been swept and everything is ready. I don't leave door cracked too long because of the tendency for smoke to billow out (this has been a thing, esp on reloads) but once I close it when it seems to get going pretty good, the fire nearly dies. Dry kindling. About 19-20 ft from stovetop of insulated ss liner in center-house masonry/clay tile chimney (with 90 double wall going in to it). All that done according to spec. Is it just a clean stove box w no ash? I'm obviously still learning. First fire of the season. I do have screws in those doghouse holes, and because the fires seemed a bit out of control last winter, but also this spring, the sweep put in a small patch of metal plate to partly cover the primary hole that is always open even with air control fully closed. Maybe that's too much? Air is still all open as it would be anyway.
Also (and maybe this second question is for another f45 thread), how often will the secondary air manifold need maintenance? I'm just thinking ahead (maybe). I only bought the stove last year and started burning it January 2025, so I don't think it will need cleaning there by now, but I am wondering about fly ash accumulation and what the likelihood of blockage might be. I would have a pro/sweep do this when it needs to happen, but I want to learn. I'm a scrappy and have some strength, but not prob enough to do the lifting involved. (Also don't have the tools or all the knowledge or time, so hiring a pro seems to make sense.)
Is this for an F45? Maybe start a new thread on your issues. Not sure what you mean by metal plate on primary air? Sounds like you may have cut off too much air. Maybe better to leave the stove as is and try a pipe damper.
Reactions: NickW
Yes, f45v2. I didn't start a new thread because it seems like you're supposed to keep these together and the original poster was talking about having trouble with startup fires. The plate it's not really a plate. It's like a little bit stronger than metallic tape and was put on to partially cover the hole in the front of the stove underneath. This was because it seemed putting the two screws in those dog house holes wasn't sufficient. (That was something I read on this forum to do.) My chimney sweep put in the little piece of metal, but that's really only sticking to the underside of the stove, so it's not blocking the air; it's just sort of in the way of it. But I don't know if that's even the issue. If I need to move this question, I will. Just didn't want to clog the forum with another thread if it was relevant to one already in place.
Reactions: Todd
What may have been good for draft at 10 degrees really hurts it at 30 degrees. Ditto what @Todd had to say about the damper. Possibly wide open in warmer temps and partially closed (in stages like the air control) at colder temps.
Also note that when draft isn't strong it's important to get every piece well charred before closing the door fully or shutting the air down. My Stratford 2 zc typically needs the door closed but not latched for awhile once it's lit and burning well to get the temperature up yet give a little bit more air to not kill it.
Reactions: Todd
Not a 602 but a jotul 118 clone.
This top down should work for you.
And you don't have to keep the door open nearly as long, it's just to show the fire spreading for the video since the door does not have ceramic glass window.
Update: I believe I've found the primary culprit for my high temp issue. Todd referenced a modification video that I'll link below.
In the video, Off Grid Simplicity takes apart the damper assembly and I noticed a horizontal gasket that is sandwiched between the inside of the glass and the damper slide housing.
My stove was missing this gasket and I only knew because I had installed a new gasket on the outside of the glass a while ago because the original installation was so poor. I would not have known about this deficiency if Todd hadn't pointed me in the right direction, so I thank you good sir. Based on how the outside gasket looked, I'm not at all surprised that the inside piece was missing entirely! Check your gaskets!
So, new gasket installed and several fires later, I still have lots to learn but I can actually get this fire to hold reasonable temps! Almost like it was designed and advertised to do! Remarkable how effective proper installations can be.
I might eventually modify the damper housing, but for now I'm happy with the performance. I'll be sure to update the thread if I do so. One final note to any other 602 V2 owners who come across this with similar issues: I still have to be VERY aggressive with the damper. I wait until flue temps come down to ~350F and refuel with two new splits. Shut the door tight, damper wide open. When the fuel ignites, I give it about 30 seconds then move the damper to the middle position. After another 30-60s, I shut 'er down. The flue temp consistently comes up to 450-500 after that. If the flue temps drop, I'll give it the slightest bump open on the damper, let the flames roll for a bit, then shut it again. Like many have said before me, this stove is an easy breather.
Thanks again to everyone who provided advice, looking forward to reading more of your posts in the future!
I’m surprised that gasket was missing! Lucky your glass didn’t crack. Doesn’t take much extra air to mess with things. Glad you figured it out.
Reactions: Burnin Since 1991
I'm going to close out my portion of this thread with one final post for future visitors. I finally got tired of hot fires that were safe but well above what they needed to be to keep my house warm. I caved and followed Todd's recommendation to grind off the damper housing tabs that prevent the primary damper from shutting completely. The task was pretty simple, completed in about 10 minutes with a Dremel and a high speed cutter bit. Perfect tool for the job, though a bit primitive for puritanical machinists.
I've got to say, I should have done this right off the bat. I keep it cracked most of the time anyway, but when the fire really starts to accelerate I'm able to shut it down and the temps come down to a reasonable level, about 400-450F STT. This provides a fire that lasts about 3 hours instead of 2 with spruce, and produces a softer heat output that's more tolerable for my home.
Thank you again for everyone who responded and helped me out. I'm glad to be a part of this community and learn something every time I come here!
Glad that mod worked out know you can mess with the secondary air!😂
Over the past few months, I still haven't been happy with the performance of this stove and looked at purchasing a different heater to serve my purposes. However, in a last ditch effort to save money, I modified my flue hoping to get better control over this stove. I think I've finally accomplished a method to maximize the efficiency of the Jotul F602 V2, get my fuel to last a little longer, reduce flue temperatures (heat leaving the house), while sustaining higher stovetop temps. Hopefully, this information will help someone else out; my journey with this little heater has been very frustrating but I am now willing to give it another winter and see how well it performs in the more demanding season.
Originally, I was using the Jotul flue collar, Jotul Metric Vent Adapter, then ICC 6" Ultrablack pipe mounted to the Jotul adapter. I noticed that there was substantial air gap (at least 1/8") between the ICC pipe and the Jotul adapter. A few weeks ago, I added an ICC pipe damper, a gasket between the Jotul flue collar and the Jotul Metric Vent Adapter, and an ICC Ultrablack Stove Adapter (shown below) between the Jotul adapter and the ICC 6" pipe.
Now, the stove is much more controllable, and I have to leave the primary air damper slightly open to prevent the fire from smoldering. Stove top temps are right at 400-450F with flue temps around 400F. So far, I have not used the pipe damper at all. My best educated guess is that the gap around the flue adapter was causing a venturi effect, increasing air flow in the entire flue which pulled more air through the primary and secondary air inlets even after shutting the primary air (modified) all the way down. I'll provide another update again when we get into colder temps, but so far I'm very happy with the results of the flue modification. I have a very strong feeling that I'll be able to pack the stove full and keep temps within control, extending burn time and reducing flue temps like I originally desired. Expect more posts to follow around November or so.
[Hearth.com] High Flue Temps and Difficult Cold Start with Jotul F602 V2
Reactions: NickW and Todd
Awesome! I can’t wait to see updates come burn season!
What outside temps are you burning in now? I can see where outside temps could make it hard for the chimney to function at the moment!
Nice! I had a gap like that on my F100 and I jammed some gasket in there for a tight fit.
It's been between 40-45F the past couple times I've had a fire in it. But you're absolutely right, it'll be a lot more obvious whether or not it changed anything once we're back in colder weather.
Reactions: Todd
