High Flue Temps and Difficult Cold Start with Jotul F602 V2
Posting here to update now that we're in some colder weather. I'm about as content as I can be with the performance of this stove now. Although I wish I could get longer burn times, I think it would be unreasonable to expect any more out of this stove than what I am currently getting. Since the flue modifications, I've been getting 4 hour burn cycles with spruce with enough coals remaining to reload. Here is my recipe for success on reloads for anyone who might be facing similar challenges to me, see my previous postings to see what I had to do to tighten up the flue:
After reloading, leave primary and flue damper wide open. When flue temps hit ~300-350F, turn key damper to 45 and shut primary damper halfway. When flue temps reach ~400-450F, begin shutting primary damper down in small increments to keep the flames rolling but slow the burn rate. Eventually stop once nice secondary burn flames are witnessed and some blue/orange flames come off the log pile. With the primary damper modification, the flue is cracked just a sliver (I don't think this would be achievable with the factory damper position and the fire would still overheat). I typically see STT between the hot plate and the flue collar at 400-500F with flue temps in a similar range. I have to reopen the primary damper incrementally as the fire burns down, otherwise it smolders and smokes.
Yes it's lots of micromanagement and I can't leave the stove alone and feel great about it. BUT, I am much happier with my burn times and the heat I am getting out of the stove. If I don't want to micromanage it, I only put two splits in and keep the primary cracked with the key damper wide open, gets hot but doesn't want to overfire.
Generally, I cannot confidently recommend this stove to anyone who is looking for a heater to burn softwood. However, if you already have one and are looking for methods to get more out of your stove, I hope this post can help a little bit.
Reactions: Todd
That sounds pretty good for Spruce, do you have access to Birch? Could the Spruce be too dry?Are your flue temps internal or external? Raking all the coals forward before reloads I assume?
Our birch is not the best quality but I have some seasoning right now, hopefully ready for next year. The spruce is still sitting around 15%. Flue temps are internal in double wall pipe. Raking coals forward every time.
I should clarify my recommendation on this stove. I would not recommend it if someone is looking for a heater to keep their house warm >50% of the time. If someone wants to use it to warm things up for a few hours or plans to keep it in a shop, that would be a great use case. These are great little stoves, just not the most efficient for heating a small house most of the time or to "set it and forget it."
Reactions: NickW and Todd
Yeah that’s what I found when I had my 602 installed in my small cabin even burning good hardwood. If the firebox was just a bit bigger say 1.5 cu ft you could probably get consistent 8 hour burns. I ended up installing mine in my workshop and it’s perfect for that.
