Jotul 602 V2 questions
Buttertart
1
Nova Scotia
Howdy neighbours - long time listener, first time poster. My household is new to heating with wood. Have had a jotul 602 V2 installed in our masonry fireplace, with a solid 20' of stainless steel stove pipe through the chimney. chimney. Very happy with how its turned out. For any of the jotul 602 experts out there, a couple questions:
  • Thermometer placement - Given the set up, i can't put a thermometer 18" up the stovepipe. 8" sure, but not the ideal placement. What's the best alternative. On the side? On the top, and if so, at the back? And if measuring temp on the surface, what's the ideal temp?
  • Loading - just how much wood can/should i pack into the box if i'm reloading with a good coal bed? I feel like i'm underfiring, but really not sure, especially with the ???s about the thermometer placement
  • Glass gasket - mine seems to have come loose at the corners. is this normal? if not, is it a problem? If so, do i need to fix it now or is it a 'get around to it' problem
Thanks in advance
Christopher, Nova Scotia
  • [Hearth.com] Jotul 602 V2 questions
Reactions: Todd
@Buttertart, it's great to hear that you're enjoying the stove! I've had mine for the past three years heating my small house generally enjoy mine as well for what it does.
Probe thermometer - I placed mine at 18" and it has been very consistently accurate. I imagine one of the more experienced experts on this forum will have some advice soon, but I can't see any reason why the probe couldn't be installed lower toward the flue collar, it'll just read higher. However, having used both a stovetop thermometer and a flue probe, I've gotten to the point where I think I could just trust the stove top temp and not need the flue probe. I also use an IR thermometer to get exact temps when I'm feeling really nerdy. I had to email Jotul directly and they recommended taking the temp between the flue collar and the burner plate. I've found that 450F at this location seems to achieve the perfect burn for me.
Loading - I'm burning softwood so take that with a grain of salt. I usually put in two wedge splits on the bottom and one on top between them, about 3-4" cross-section. Sometimes I'll put 4 in if I can fit it and want a longer, hotter burn but this also makes the stove get hot enough that I feel uncomfortable.
Gasket - I noticed that my glass gaskets were poor right from the crate. I would just replace that door gasket now to save yourself the headache of the air leak later on. Mine looked exactly the same. If you do that, keep in mind that there is also a single strip of gasket on the primary air damper that you will want to make sure gets reinstalled correctly when you're done. The job is very quick to accomplish. I'm still happy with the door gasket though and haven't replaced it yet. It's coming loose in a few spots now so I'll probably be replacing it when the winter season is over.
I have a probe thermometer on mine at about 18” up and start adjusting the air down when I reach 400-500 degrees. If you use a surface magnetic thermometer on single wall pipe it roughly reads half the temp of a probe. Yours will be lower so it will read a little higher but it will still be useful as a guide.
I would remove the door and inspect that gasket. Looks like the gasket glue failed and the gasket came loose. You could probably still use that gasket if in decent shape, just clean the groove and reglue. Careful when you take it apart. On top of the glass there is no gasket, this is for the air wash. The top sides are folded back over the glass about an inch to protect the glass from that top bracket air wash plate. It might be better to just buy new gasket from Kingdom Wood Stoves. He sells the proper kit and has excellent instructions.
If you’re reloading on a large coal bed don’t over fill. Just a couple splits at a time. I have found it easy to run away on me with a large coal bed and will only fill it full with less coals. Always rake the coals forward before loading, this will give you a longer more controlled front to back burn. I like to use smaller splits about 2-4” diameter and a little less than 15” long. With good hardwood you should see a good 5 hours of usable heat on a full load and I’ve seen coals left after 7-9 hours if done right.
A 20’ chimney may pull hard at times , you may want to install a pipe damper if needed.
