- Feb 3, 2013
- 14
I did some searching and while I thought I read it on here last year, I cannot find this information.
I am installing a couple of crude heat exchangers (old cast iron radiators) parked next to my Hearthstone one to assist in heating the cold return on a FHW two zone home. My idea is that they pre-heat some water and dump into a 40 gallon rock lined tank so when the zone calls, I have a little stored hot water ready, hopefully to delay or negate the oil burner kicking on. I may do a copper coil around the stack pipe to boost the temp, but I don't want to push pressure up too high to worry about anything. Don't worry, I will have a temp and pressure relief and a spot to plump in expansion AND if I am lucky I will plumb in a heat dumping loop on natural thermosiphon.
My question is do I send cold in the top or bottom of the radiator. I know heat rises but I thought I remember reading a few posts suggesting that forcing heated water down (by flowcheck valve at the beginning of the loop) will create a directional flow as desired.
My other question is: should the "heating pickup flow", (flow next to the stove in the crude heat exchangers, ex. above) work in the same direction in the 40 gallon rock line storage tank? Should the recirculating loop off of the tank come of the bottom or the top?
Thank you
Thank you
