This is what i found to work EXTREMELY well for me...
i have pacific energy summit insert
first load the back of the stove e/w i use 2 pieces on top of each other almost the exact width of the stove..(if wood is semi seasoned put it back there) then i load n/s as much as possible (with smaller splits in length) then bam
(of course wood is dry)
you get a hot burn cause its n/s but you will get a longer burn because of pieces e/w in the back!! if your wood is semi seasoned in the back it will be kiln dried by the time it actually starts to burn or catch "fire"
when i burn like this i believe i can get 14 hrs outta my stove But it will be down to about 250 at 14 hrs... guessing
stove says 10-12 hr burn with ebt so if this can plus your stove 2hrs its about 15-20% longer burn time ... please try it and post results!!
if you have any other sugg please post stove type along with what you do!!
this should help our newbies big time
(of course wood is dry)you get a hot burn cause its n/s but you will get a longer burn because of pieces e/w in the back!! if your wood is semi seasoned in the back it will be kiln dried by the time it actually starts to burn or catch "fire"
