Going from QF Discovery to ?? insert. HELP!
Vidiot
1
MD
We have been using a Quadrafire DiscoveryIII for 3 or 4 years now. It is the 1st wood stove either of us have used so no real experiance. We have had no issues aside from getting good sessoned wood but that is another topic. We have a brick fireplace in the same part of the house and plan to put an insert in there and get rid of the free standing QF D3 to save space. Its a 2500 sqft rancher and this is in the center of the house. We understandably have trouble getting the two far ends really warm but it makes for good sleeping in the bedrooms out there since we prefer it a little colder.
My questions are :
1) Do you think we will struggle to get as much heat off an insert as we do a free standing unit?
2) Is there a stove that will give enough (atleast what we get now) heat but with a longer burn time since we struggle to get an overnight burn from the QF D3?
I am of course considering a BK Princess 29 as I can't find a bad review and like the idea of longer burn times. I know this is a cat stove and am guessing I will be able to get cooler burns for shoulder season but will it give me the heat I need when its properly cold? My installer recommended the Osburn 3500 and I like the idea of the large firebox suggesting longer burn times. Its also rated at a much higher BTU output than the QF D3 but it seems there is no real apples to apples on the specs so here I am. Spinning the interwebs... Any advice would be greatly appriciated.
An insert will heat differently than a freestanding stove which has more radiant surfaces exposed to the room. To come close, the more an insert sticks out of the fireplace onto the hearth, the more it will heat the room without convective (fan) assistance. Both of these inserts are good in this regard.
If maximum heat output is the goal, then the Osburn 3500 is a good choice. It has a large firebox that can be loaded N/S or E/W and can put out a substaintial amount of heat when pushed, yet is still able to burn a smaller, 4-5 split fire when not. It's a conventional, and simple secondary burn stove that with care will last a very long time with fairly low maintenance.
If milder weather heating is the primary goal then the Princess is a great choice. It will definitely have a longer burn time and has a solid reputation behind it. You can load it up and dial it down for a nice low and slow burn that will go on for hours. The firebox is a bit shallower than the huge Osburn which biases it toward E/W loading unless the splits are shorter. With the tech that makes the stove great comes additional complexity and maintenance but it's not onerous and with proper burning habits will become routine.
Reactions: fao1989
Hello, Osburn 3500 owner here. The Osburn will definitely give you overnight burns. It has a huge firebox so that is no problem. Please note, by overnight burns I mean that there is plenty of coals to easily get the morning load going with no problem. The blower fan has a temperature control that will shut it off when the stove burns out and gets cool. In the cold months of winter, if I load it up with a full load of wood before bed around 9 pm the blower is usually still blowing in the morning when I get up around 6am. In other words the stove is still fairly warm for an easy relight.
I used to own a Woodstock Fireview catalytic stove at my old house. It was definitely better at the low and slow burns and I feel it was more efficient than an insert because it was able to radiate more heat out. But it's not an apples to apples comparison because my old house was laid out completely different than my current house.
I will say that with very dry wood (around 14% moisture) I can turn the Osburn down quite low once it gets going. In milder weather I can turn the blower to about half speed and get prolonged secondary combustion with stack temperatures in the 500-600 range as measured by an Auber probe thermometer about 6" above the flue collar. I have an insulated liner with a blockoff plate. Also in Jan and Feb I remove the surround trim from around the insert to allow the warm air to flow out of the fireplace area around the insert just to get every last bit of heat out.
Reactions: begreen
Here's a thread from many years ago by a member who switched to a Blaze King Princess Insert in his home in Maryland. It's worth a read.
Reactions: EbS-P and begreen
You may also want to look into the Englander Blueridge 500i if you’re looking to save a bit of money. From what I can tell it seems like it’s the same exact stove as the Osburn minus some nicer aesthetics. Someone else may be able to correct me on that if the Osburn has some other features I’m unaware of but they are both SBI 3.5 firebox.
Reactions: EbS-P
As a BK insert owner who loves his Ashford 25 I'll add the following two points.
- To reinforce begreen's wisdom, " the more an insert sticks out of the fireplace onto the hearth, the more it will heat the room without convective (fan) assistance." I contemplated an ashford versus a princess insert. Delighted with the Ashford in my boxy large living room., which supplements my heat pump. But if my home floor plan was more open, or the connecting hallways didnt have ceiling transoms, I might have gotten the Princess insert in my brick fireplace. Seem to recall somebody (maybe BKVP?) observing that a princess is more of a "hearth heater" - meaning it projects more heat, by sticking out further, vice a shallower insert.
- If I wanted to heat my entire house - I would have gotten a stove, vice an insert. Not sure somebody who is used to heating a house primarily with a stove will be completely satisfied with an insert on colder days. If you had a stove, you might want to stick with a stove. And it's hard to beat a BK!
Inserts can absolutely heat the house. They just need a blower. A stove set in a fireplace needs a blower. A freestanding install can produce more heat/allow a faster burn rate with a blower.
If you need maximum output you should have a blower.
