I got my insert installed. They used an insulated liner per my request. I have a block off plate. But, I think I have some issues that I want to fully understand. The installer was very professional and got this thing installed without scratching a thing. He was careful. However, he use a 45 degree elbow from the insert to the liner. I did not see how he attached the liner, but he did not use fireplace cement as per the manual. I also see a small slice or cut in the elbow. I can see flame in this slice with the lights off in the room and the door seal cracked on the insert. When I crack the seal on the door, I get a much stronger fire. When I then lock the door, the fire seems to choke. I have the air control fully opened. I am not impressed with the performance at all. I am wondering if this elbow connection could be an issue.
I do not believe Roxul was used. A very chunky kind of insulation that came in the form of what looked like a big ceiling tile was used. I can see some of this loose insulation blowing along side of the pipe as it exits the block off plate. It is dancing ever so slightly.
Any feedback or ideas. The installer says he will come back and seal the pipe and seems like a stand up guy, but I just am looking for additional advice on what to check to make sure this comes out the best it can. I am also going to start another thread on the proper operation of the catalytic combuster. Thanks.
