franklin cast products scandia 100
west pa guy
1
portage,pa
I recently aquired a Franklin cast Scandia 100 wood stove ,quite ornate in my opinion. I will be posting a picture here if some here want me to. I was told that it has some baffles that would make it more efficient and i received some steel plates but I do not see how they would connect inside the stove. Is anyone here familiar with the Scandia 100 or know of where I could get the info on the parts inside the stove and how they connect together? Thanks in advance for your consideration.....Dave
Did you find the info you were looking for? I have a Scandia 100 with an owners manual.
It goes together the same as a Jotul 118, side burn plates should hang on the tabs on the sides, and you pop the top and set the baffle in from the top.
