Two years ago, we changed a fireplace insert to a wood stove insert. Due to the size limitations, we went with the Buck Stove model 74 w/ blower. Everything from top of chimney to bottom was replaced.
Now that we've used it for a couple of years, I wish I would've just put a free standing wood stove instead of going with this insert. The main reasons are the small box leads to having to load it more often and I would like more heat from it. The box is rather small and I can usually get no more than 4 hours from it. If it's really cold out, I have to set the alarm and get up during the night to reload it. I read that it gives about 40K btu's which is far less than many wood stoves. I'm attaching a picture of the current setup. Has anyone done this, changed from insert to a free standing wood stove? If so, how did it work out? I'm picturing the wood stove sitting directly in front of where the insert is now.
The house is a cedar log home, 1700 sq ft split level, main living space has 26' vaulted ceiling which vaults directly above where wood stove insert is. Running the ceiling fan in reverse on medium speed helps to stir up the hot air that gets trapped up high. We also have propane wall heaters. We cannot heat the home with the wood stove alone. I'm hoping a free standing would heat it without the use of the propane heaters.
Any insight is appreciated!
![[Hearth.com] Free standing wood stove in place of insert? [Hearth.com] Free standing wood stove in place of insert?](https://www.hearth.com/talk/data/attachments/221/221085-f7cbae648d2a9ceaeb95c9e1a6021aeb.jpg?hash=s0mnbXXYXu)
