Now I have a question about the fresh air intake side. Manual say any large runs (6 to 8 ft) could starve the stove of air. Problem is mines maybe 16 ft to the outside. If I increase from 2 inch to a bigger supply pipe would that work?
I'd be curious about your exhaust side...I haven't done one at my mom's but if we did we'd be in similar situation but the chimney is a 2 story chimney, so a little bit of heat would really pull some air beyond what the convection fan could push/pull. So short question, does your exhaust side have enough vertical to help assist with the air flow?
According to the Harman manual it should be fine. Just calculate all your piping. As long as it under those allowances. There’s also a max length on the horizontal run.
Equivalent Vent Length: The equivalent vent length for common pellet vent components are:
• 90° Elbows or Tee: 5 EVL Units
• 45° elbow: 3 EVL Units
• Vertical Pipe or Liner: 1⁄2 EVL Unit
• Horizontal Pipe or liner: 1 EVL Unit
The total allowable equivalent vent length is: • 20 EVL for 3” pellet vent pipe or liner.
• 30 EVL for 4” pellet vent pipe or liner.
Now if you move to a comfortbuilt stove they actually tell you the feet. See attached. I’ve been reading a lot to make sure the install will work.
I think I’m going to increase the size of the fresh air just to be safe. It should be fine
Direct-Temp for Pellet is a direct vent system for pellet fired appliances. Available in 4" x 6 5/8" Diameter For use with 3" and 4" pellet appliances Stainless steel welded seam inner Heavy Duty Galvanized Steel outer Unpainted or Matte Black Finish High efficiency performance Kits...
I ran into a similar issue with my Harmon PB-105. My stove is in the basement 10Ft below grade, and the back of my house gets pretty deep snow, so i wanted my fresh air intake to come up about 3Ft ( like a snorkel) I used 4" galvanized ductwork to make a snorkel for the outside portion and ran as much as I could inside. i reduced that down to 3" and flexible dryer ducting for the rest of it. Stoves been burning great for 2 months, no issues.
I also ran the chimney straight up thru the soffit, so I have sufficient draft to help pull fresh air into the stove.
