Hello Everyone,
My new install of a Lopi Large Flush NexGen-Fyre has chimney clearance issues...Had the dealer came in to repair door gasket since it pulled away during a "cure burn"....Yes I did open the door several times to avoid that problem, but bottom gasket failed anyway....I questioned the owner why he installed a heavy duty 6" single wall liner without proper clearances....1/2" to 3/4" clearance to masonry chimney a code violation? How the hell does an owner know the internal clearances?
Why wasn't I advised before his team hooked up the new liner?....Not a happy camper.....I told him I wanted a twin wall but he uses a particular liner that is much thicker than most...He explained if applying a ceramic blanket (labor intense I'm guessing) it may be shredded if it is installed...I told him I'm getting an IR gun to check interior/exterior temps....
Upon leaving my "chimney specialist" advised he wants to make me happy....That they would come back and uninstall the setup and modify....but a new crown would be needed another $300 bucks...and I imagine labor costs as well....
My question ladies and gentlemen, what should I do?....Would changing the round 6" to an oval help? Can a blanket surrounded the oval?. Don't know how thick these blankets are! ...Should a reducer have been used?...Will there be performance issues afterwards?...What is the best option at this point? The outfit I used is certified...If I wasn't relentlessly pursuing this issue, installers would have gone their merry way...How the heck can the oval such a heavy duty liner?
Thank you all who chimed in on Winter Warm Just Died thread which was getting too long....I also read the thread where TE was helping Tiffany and her mother with their Lopi back in Nov'22- fantastic advice...
Feel like a cat on a hot tin roof!
