in the past week, i replaced the tile surround that went around my ngas fireplace with a eldorado stone surround..the ngas fireplace was installed in 2004 into an existing zero clearance fireplace space. while i've noticed cold air before coming in around the ngas fireplace, i never noticed nearly as much as i have coming in now and i've never had frost on my fireplace. i'm not sure if it's because i
a) don't currently have the pilot going on the ngas fireplace which usually keeps the fireplace quite warm
b) because i brought in the edges of the eldorado stone much closer into the edges of the ngas fireplace frame so the cold air is concentrated through a smaller space
c) a combination of both of the above.
i haven't fired up my fireplace pilot as i have to clean up the frame and glass at this point from my stone surround build still and i thought i might bake the guck on at this point.
so, let's assume that running the pilot takes care of the frost issue and the cold air coming in gets warmed up, i feel it's still very drafty..it's a direct vent fireplace so if i were able to seal it off more to limit the cold air coming in the edges, i think that would be a good thing? i was thinking a place to start might be some kind of gasket that won't melt or burn that sticks to the frame that the ngas insert backs onto. the weight of the insert would help seal the fireplace somewhat? i also was thinking of dropping batt insulation into the cavity behind the ngas fireplace insert..i know that won't help drafts but thinking it would at least create a barrier so the space doesn't get so cold. any thoughts on those ideas..or any other ideas?
edit- here's a product i came across that sounds like it would be helpful maybe?
(broken link removed)
