Help with converting Heatilator 34A wood burning fireplace to a Propane insert
chap442
1
Arkansas
I am in the process of converting my Heatilator 34A built in 1994 and used maybe once a year- skipping some years! Wife wants a gas insert.
My main questions are suggested brands- preferably made in USA--if that is a thing.
Secondly, pricing- is there negotiating room for discounts in the off season and if so how much is reasonable?
Local fireplace shop recommends , Fireplace Xtrordinair (Travis Industries) , Heat and GLO and Kozy heat
Prices listed in show room range from $5700 to a low of $4500 plus tax and installation ( Install was quoted at $1750) with gas stub in the fireplace already - more if Propane gas line has to be run ) which it does.
Tax is going to be about 7%
Any help would be appreciated
Ensure your Heatilator fireplace can have an insert installed in it- the manual for it can guide you. If it can, it will say what can be removed to facilitate installing an insert as well. Most ZC fireplaces are smaller inside than the masonry styled and will allow some altering if needed. All the units you mentioned are quality heaters, we are a Kozy Heat dealer here, love their Chaska line of inserts, very solid and more reasonable priced than a lot of inserts. Their new Nordik inserts feature their raised burner, looks like a campfire burning. Good luck in your search.
Reactions: Millbilly
