But you omitted an important part from the article:
Soapstone stoves are designed to provide constant heat throughout the entire heating season: they're not designed for occasional, short-duration fires. When you first light a fire in a cold soapstone stove, the stones absorb heat which, in a typical plate steel or cast iron stove, would rise up the chimney and get the thermal updraft going. Thus, soapstone stoves require a bit of patience at lightup time.
The general consensus is that the initial smaller fire and draft issues are when you start the stove at the beginning of the season. I have posted before and will again that I would never recommend a soapstone stove if it is being used occasionally. Mine has been at least 200
on the top of the stove since it's first fire when installed this season and that low temp is with minimal coals to allow a complete clean-out of ashes. It's almost always 400+. Your reference tells me that you are confusing a start-up fire with regular operation. The only difference between my soapstone stove and my former cast iron is that it will take a bit more time - maybe 15 min - to feel the heat in the room. Other than that, the operation is identical. The information posted about 'a bit more patience at lightup time' is completely opposite my experience with other stoves - just not true at all.
So, if you are using your stove once in awhile, you probably aren't getting the benefit it was designed for. Still, your posts keep telling me that you have a draft problem, plus a stove problem. It continues to puzzle me when I read back on so many other threads here that the OP finally gets convinced to add 4' of chimney and the multiple problems the OP has, miraculously disappear. I strongly suspect that this will happen with you.
It all comes down to dry wood and good draft.
These are some of your posts:
- I'm having occasional weak draw and have noticed smoke exiting a joint in our double-walled connector pipe between stove and ceiling.
- One thing we've learned is to crack a window if turning on the kitchen stove vent fan or bathroom fan. This is a tight house and the external air source on the wood stove can't keep up with furnace draw plus vent fan draw.
- Mainly what we notice is a smoky smell when we come into the living room in the morning.
Yes, there's a learning curve with wood heat but somehow, you've got to solve the draft issue. I think I read that you have an OAK on your stove. I'm not sure if your stove design is the same as my Hearthstone Equinox or not. The Equinox with an OAK installed gets ZERO air from inside the house. All combustion air comes from one opening and that is sealed to the fresh air vent - OAK. Opening a window or operating a fan makes ZERO difference in our house and it's air tight also. It was pressure tested when built. As I stated, I do not know if your stove is different but most Hearthstone stoves are designed very similarly, just different sizes.
Add to that the fact that your stove is 1.2 cu ft./36,000 BTU rating. To me, that will heat a medium sized room and no more. You've got 3,600 sq ft. house!
My stove is 4 cu ft/120,000 BTU rating (3 times the heat) and I'm heating a lot less house but probably in a lot colder climate.
Not trying to be nasty, just want to point you in the right direction so you will be happy.
You are learning the right way to burn - load it full and let it produce heat. I'm still criticizing my wife who puts in 3 or 4 splits that will only last a few hours. Whenever possible, it's as full as possible and almost always, the coals will ignite the whole load within 5 minutes or less. I haven't used a match for a month, even after cleaning out the ashes. Honestly though, a 1.2 cu ft. stove won't be hot through the night, so you'll constantly be restarting it.
It feels to me like somebody sold you the wrong stove and you need a higher chimney. Sorry - just my opinion from a guy who's been there.
