I could use some input. My oil burning furnace is venting improperly. It's horizontal in my crawl space. It is relatively new, so I am assuming it was installed to code, but I don't know. When I bought the house 2 years ago it did not come up as an issue on the inspection.
Furnace guy comes and tells me it vents into a horizontal concrete chamber and then up a chimney. He says he's never seen a similar set up. He gives it the side eye and tells me the chimney is blocked and needs to be cleared. I pulled out a piece of siding at the bottom of the chimney and it was full of ashes and soot.
I take it my best case scenario is just a blocked chimney, but should I be concerned about the distance/angles the effluence has to take before it gets to the chimney? Any other concerns in the pics? The guy even mentioned I might need a chimney liner :gulp:
(broken image removed) (broken image removed)
