I have a Garn 1500 and have been using it for two seasons now. Love the stove but unhappy with my mixing valve setup. I have a Taco 5000 series mixing valve on the output Garn supply manifold and cant keep suitable and steady temps out unless the tank temps are 150 plus. I can heat the house well with 140 degree water and would be happy with that as a max temp. I have been considering one of the Taco I series mixing valves with outdoor reset as a replacement. Looks like a 3 way valve would be a direct swap in as an upgrade. Will this type valve give me steady temps out with tank temps below the setpoint? Obviously the output temps will drop but will they stay at supply temps below the setpoint?
My other thought was to just take water directly from the supply manifold at the Garn and use a circulator in delta T mode to monitor supply and return water and allow it to adjust.
Thanks, Bill
Thanks, Bill
