aside from our opinions have you come up with any information, pellet burner mfgrs, or dectra ect?
No information at this time. I'm looking at pellet boilers or pellet burners that can be installed in a oil fired boiler and use hot water to heat a large hot water tank or tanks and or a Garn Boiler. A little confusing looking at the two forums. One being pellet stoves and the other wood boilers. Are pellet boilers in the wood boiler forum or under the pellet stoves forum ?aside from our opinions have you come up with any information, pellet burner mfgrs, or dectra ect?
You are correct, the Effecta is designed to do this. I know Morgan up in Alaska has this set up. Tom is correct though, you have it set up for either wood or pellets - it can not automatically switch from one to the other. My understanding is the swapping between the 2 is fairly easy and quick but I have now real knowledge. They also make an awesome pure pellet boiler if you decide to go that route.Wouldn't it be easier to buy a system that is designed to burn either pellets or wood?
I believe the Effecta boilers can be purchased with a pellet head that is supposedly very simple to switch back and forth.
One way of looking at it is that it is just another burner. They do burn well and are compatible with some oil fired units as a retrofit.What's the difference between that and a regular pellet burner?
Steve, I figured something was up, sorry to hear you are that busy, with the heating season approaching doesn't seem like you're going to get any rest. Did your boys get a vacation?
