slowzuki said:Jim do you have 2" with a minimal number of fittings up to the suction side of your pumps and is your main pump high capacity? It doesn't take many fittings to add friction.
slowzuki said:I
The 2" tapping does reduce the effectivemess of a 2.5" pipe a bit, but it is far better than using 2" pipe.
rvtgr8 said:Jim,
I looked at the flow rates on the difference between 2" and 2.5" pipe and it seems significant in terms of actual flow. I lowered the pumps for the cavitation problem. A 90 plate HX on 2" looks like I can deliver almost the full monty from the Garn (500K+ btu) to the existing system which is rolling along with a Burnham capable of producing 136K btu's. I realize that I will have future loads, is it your opinion that my exchanger should be sized for the maximum amount of output?
PS - No worry about sharing the thread.
slowzuki said:Jim/Robert, I just checked some quick numbers and you should be good with the 2" as long as you don't go crazy with elbows. Jim, bigger pipe will increase the NPSH available at the suction because it reduces the friction loss. Its far more important to control friction loss on the suction than discharge. You can't fix cavitation, but you can pay for increased pumping costs/more powerful pump to solve the other side.
Robert, a 2" return to the tank is a good idea. If you are guaranteed to have all high head circulators it wouldn't matter much but by making it large, it will reduce problems with choosing circulators in the future once you add loads. Besides, it will save you a bit of power while running your circs.
rvtgr8 said:Jim,
I have the opportunity to buy two of the the Taco 0010 ZF3's new in the box for $200. I guess I could use the other one for the hot tub and radiator. Or do you think that that is too much power on the HT loop?
Jim K in PA said:According to the specs (http://kingsolar.com/catalog/mfg/taco/0010zf3.html) They will only flange up to 1.5". I thought you were going with 2" on your primary manifold.
