[quote author="heaterman" date="1227871057"][quote author="Garnification" date="1227787400"]Heaterman,
What do you think about the switch in supply/return setup on the garn?[/quote]
I have always used the bottom port for supply to keep the maximum amount of head available at the impeller inlet.
Not 100% sure I buy the theory of using the top tapping and mounting the circ low of from that. I have to install a 2000 next week and I'm going to give Martin a jingle and quiz him on it. Seems to me that once you've exhausted the quart or two of water in a 3' piece of 1.5 or 2" pipe you're left with virtually no head on the suction side of the circ. The static pressure available is only what is in the pipe.
I usually try to engineer my piping so that I can flow 20-25GPM through the Garn at a minimum to keep it turned over in a reasonable amount of time. Primary/secondary works nice for that.[/quote]
As I am reviewing my installation plan, I am reading through the past posts and gathering valuable information. I came across this post which got me to question taking the supply from the top port. I noticed some taking the supply from the top and some from the bottom port.
What would you do now that some of you have more experience under your belt. Would you still plumb supply from the bottom or upper port?
Thanks, George
Thanks, George
