I am working on an Osburn Bay Vista natural gas fireplace insert built in 1995. I replaced the ITT gas valve with a Robertshaw #710-511 millivolt gas valve and the pilot assembly with a Robertshaw #1819-001 pilot, thermo-couple. Also installed a new spill switch which was located on the outside of the firebox between it and the masonry fireplace. The pilot assembly, spill switch, wall thermostat, and the on/off switch are connected to the valve on what I think are the correct TH, TP, and TH/TP contacts. With the glass front off, the pilot light will light and the burner will come on. When I try to install the glass on the front, the valve shuts all of the gas off. Remove the glass and everything will work again. The fan snap/thermo-disc works. It will turn the fan on and off. I checked the flexible stainless steel flue for obstructions but found none. All of the part blow-ups on line do not show or label all of the parts well enough to identify them and the parts lists are incomplete. What am I missing that could create this problem. Open to any suggestions. Thanks.
