Gaskets Question--need advice
jimmieguns
219
Long Island, NY
i am replacing the door gaskets and i think they call for 5/16 but i can only find 3/8 inch in my area. its a TIGHT TIGHT squeeze but i think i could get it in.. IS that safe to try or best to wait and keep looking for the 5/16 THANKS!
If you can close the door and latch it then go for it. That larger one will not hurt at all.........
Craig
That may hurt the latch over time and eventually break it from pressure. I would stick with the right size gasket. Have you looked at Tractor Supply, Lowes, Home Depot, Ace Hardware places like these often carry or can get quickly what you need.
Pete
Pete
Amen on the latch issue. I came to grief on this, even though I used the 3/8 gasket recommended by the manufacturer and had my sweep put it in for me. The door was a major bear to close, and after a few weeks not just the latch broke, but the cast iron lip on the frame wore through. Because the stove was out of warranty and the company will only sell you the frame-door combo, it would have cost over $500 to fix.
Be very, very careful with replacing those gaskets, and wait until you're out of heating season to try it. I would say you're better off using a smaller thickness laid down pushed together a little bit if necessary than to use one that's too fat.
is that a vermont Castings insert? They may have used that 5/16 armaseal gasket but I cant remember for sure.
We bought our stove used and after the first few fires, being run aways, we narrowed it down to the gasket being the wrong size, too big, and letting in too much air because the door wasn't closing all the way.
Get the right sized gasket. Start calling around to local hdwre stores and stove shops and you'll find it.
OK thanks for your help
Thanks-- i guess you were using alot of wood like i am now :(
Yes it is a VC and you're right i saw online somewhere that its armaseal 5/16 you were right thanks
Thanks for sharing! yes i understand your point and it makes sense-- Thanks!
Pete
Thanks Petw-------Ace hardware website lists it-- will call my nearest store tomorrow! Thank !!!
